06.29.2008, 10:45 PM
did you try crawling with it yet? very cool if it can crawl and then pull off the rocks shift into to high gear and haul some arse..
Yep, did a bit of both. It needs better tires, that is for sure. Otherwise it seems to work fine. Swaybars would help it handle better at speed, but they would limilt its crawling ability. I may gear it down a bit, as it is a touch too fast in high gear.
