That motor is a bit small for the Rage IMO. It's barely bigger (+5mm longer) than a Mamba motor and those are notoriously bad for use in a vehicle that size. Even though it's cheap, you're probably going to have heat issues with it in that vehicle, especially on 3S. I'd suggest a different motor if you want it to actually live up to the "Overkill" terminology you're using for the truck.
Some motors that come to mind...
Neu 1105/2Y
Neu 1107/1.5Y
Permax Multiplex BL480/3D
Medusa 28-40-3400
Also, a MM is not needed for a truck that size...a Sidewinder is much more affordable and will work very well on whatever motor you choose. You also aren't going to find any 3S 2000mAh battery packs that will fit in the battery tray of the Rage. About the biggest you can probably sneak in there is a 3S 1600mAh Flightpower EVOLITE V2 pack.
Neu 1105/2Y
Neu 1107/1.5Y
Medusa 28-40-3400
where do they sell the 1100 series Neus......if you have a link that would be great, I thought the Mambas ran too hot, I have had pretty ggod luck with the Hyperions they seem to have more torque than the CC motors
thanx for the link it looks like the 1105/2y would be a good direct replacement for my Hyperion have you tried any of the 1100 series Neus?
I have not used any of them myself, but rschoi_75 has. I run a Permax BL480/3D in my Mini Quake...it's more then enough power for me. It's 30 x 50mm and ~4200kv.
