hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
07.01.2008, 02:50 AM
What's "big motor mount"??? Is a Neu is consider to be a big motor??
So if i understand, if i want to run the stock 68T with 22 T pinion i don't have any choice other than put it on high CG??
The neu 15XX uses the same size mounting as the titans,... that can be used in the low and high CG mounting places. The Big motor mounting option is well......bigger...Its for 29-30MM set motors like this;
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
Also Don't worry about the term "high CG". It's all of about 4mm higher than the other one. I think the only point of the two different smaller mounts is to give more gearing options. Still way lower CG than the e-maxx mount.
