Possibly a solution for usb on MMM
bl-is-future
bl-is-future's Avatar
Possibly a solution for usb on MMM - 07.03.2008, 08:21 AM
K well let me explain. There will still not be a USB on board BUT...
you can use a Y adapter with a switch and it should work.
You have a male plug on MMM so this should work like this.
Male from MMM to single female on Y. Split this and put a Male on one split( this is your castle link) Then put a switch on the other split across the signal wire. Then put another male on that end.(this is your rx end) Now when you want to use your castle link just turn the switch to off so the signal is not being sent to your rx. It will still power on but the castle link will not know it is on because you killed the signal and the ESC will not react because the only signal it sees is the Castle link.
Sorry if you are confused, i will test this tonight and post pictures if it works. If anyone Knows for sure this will not work let me know and i will not test it.
