DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.03.2008, 08:07 PM
Originally Posted by captain harlock View Post
For your information, everyone, the CC Neu motors are being manufactured in chaina. I do not think they are hand built, and I also do not think they incorporate segmented magnets like the ones available directly from Neu itself. All of these things were done to take down the prices of these motors by leaps and pounds.
The " Real" Neus are way better and more expensive than the CC ones. The CC ones are meant for the general public and those who aren't willing to get the original under license from Neu.
Wheres Chaina?
The "Castle Neu" motors will be build in Castle's Chinese facility, under license from Steve Neu, and we are currently waiting on magnets to arrive from our magnet supplier in China to build the final prototypes and get the production line started. The "Authentic Neu" motors are built in Steve Neu's facility in San Diego. The differences between the motors were mostly to make the CC motor better suited for RC car use -- the "Authentic" Neu motors were designed for airplane and heli use originally, which calls for lightest possible weight.
#1: Authentic Neu motors have carbon fiber wound rotors, the Castle Neu motors will not have a carbon wound rotor. (We tried, but Carbon Fiber is so rare right now we just couldn't procure enough carbon for production... but we have found in testing that the carbon wound rotors aren't significantly stronger, they just protect the stator better when the rotor fails, so we decided to move forward without a carbon wound rotor.)
#2: Castle Neu motors have a completely different case, which is better suited to RC car use (better seals on front and rear bearings, more heat sink area, heavier and stiffer construction.)
#3: Castle Neu motors have larger front bearings to handle RC car loads better than the Neu motors
#4: Castle Neu motors have high flex 10ga silicone wires exiting the case, instead of winding wires (better suited to very high vibration environments.)
Thanx!
Patrick
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
