http://www.traxxas.com/products/nitr...slayer5908.htm
Take the Slash. Make it 4WD. Make it nitro with the screamin' TRX 3.3. Add Revo suspension. Voilla. Slayer.
* Scale dimensions and looks of actual short course off-road race trucks
* Chassis nerf bars absorb impact and support the body
* Scale front and rear tube-style bumpers
* 45+ mph top speed out of the box; capable of 50+ mph with optional gearing
* Larger 150cc Revo fuel tank extends run time
* Digital high-torque, ball bearing steering servo delivers 125 oz-in & 0.16-sec transit time
* Aluminum GTR shocks
* New high-volume dual-stage air filter
* Tight-handling progressive-2 rockers
* Titanium-anodized chassis and chassis brace
* Compact receiver and battery box with integrated personal transponder mount
* Blue-anodized antenna crimp nut
* Four channel micro receiver
* Compact throttle servo mount with air filter support
* Two-speed forward only transmission
o Ultra-compact. Fewer moving parts
o Low rotating mass for quick, high-revving acceleration
o Constant drive engagement is smooth and instantly responsive
o Sealed case protects gears & two-speed from damaging debris
o Autoshifting two-speed is simple, reliable, & easy to adjust
* Large diameter front disc brake
* Mirror-polish Resonator™ dual-chamber aluminum tuned pipe
* High-revving TRX® 3.3 Racing Engine for proven championship-winning horsepower and speed
o Bigger piston and sleeve delivers extreme power
o Consistent and smooth throughout the entire power band
o Straight-through exhaust flow
o Slide carburetor
o Knife-edged connecting rod
o Large aluminum blue-anodized cooling head
o Super-light piston and rod
o High-performance ball bearings
o Backed by Traxxas Lifetime Engine Replacement Plan
* Torque-Control™ slipper clutch
* Sealed limited slip front and rear differentials
* Super-duty driveshafts
* Sealed pivot ball suspension
* Rubber-sealed ball bearings
* Hex hardware
* TQ™ radio system
* Scale all-terrain front and rear tires offer superior on- and off-road traction
* The tires include performance foam inserts and they come pre-glued on satin-finish wheels
* ProGraphix® multi-colored painted body is available in red, blue, red/black, and blue/black
* Slayer is backed by unparalleled Traxxas support and parts availability
Looks like a stubby revo to me..
