mm external bec help
hailmick
mm external bec help - 07.05.2008, 04:17 AM
ive also got an external bec q for mm
im going run my mm with receiver pack on lipos yeah racing 2x 2s x4000mah in series= 14.8v with internal bec wire removed of course
as per rc calcs or brian g site any thing else i should add to it as i dont want it to smoke
but im wondering about lvc for my lipos can i set it as custom voltage ? on mm and will it arm?
its in a pede with 9L feigao power (24/86 pin/ spur)
thanks mike
azjc
07.05.2008, 10:39 AM
thanks mike
your running a Rx pack so you dont need a BEC, and you can use the Castlelink to set your LVC I set mine @ 3.3 vpc
hailmick
07.06.2008, 12:29 AM
thanks for that i had set m lvc at 12.7 but 13.2 is logical
