brushlessboy16
brushlessboy16's Avatar
07.08.2008, 02:02 PM
it will do very well!
depending on your esc 6s would be better
mtbnjim
07.08.2008, 03:23 PM
is it better to Parallel two 6s lipos or to Series two 3s Lipos...assuming you have equal Mah and weight- which is better for performance and/or life of battery over time?
ah-see
07.09.2008, 04:08 AM
Assuming the discharge rate on both setups are exactly the same, two 3s in series would be better because there are less cells which means less chance you get a dodgy cell, also less connections = less resistance and it would be harder to keep the 12 cells in balance as opposed to the 6 cells.
