Go Back   RC-Monster Forums > Support Forums > General Nitro
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
10.04.2005, 05:00 AM
Originally posted by RC-Monster Mike
If you can get the idle low enough, the truck should shift.
For the glow plug, John-forget about the EZ start glow igniter and get yourself a real igniter. The EZ start igniter will forever give you trouble.
The idle was actually one of the first things that I did to try and fix that problem. I've got it down as low as I can get it without it stalling all the time. I'll take the tranny apart and tighten that screw up that coolhand was talking about and see if that helps.
When you say to get rid of the EZ-start igniter, do you meen to get rid of just the blue wire that goes to the glow plug and use an igniter instead? Or get rid of the whole EZ-start all together?
I really like using the EZ-start so if I can keep that and use an igniter I'd have no prob with buying one if I'm going to keep having problems.
Thanks.
