I have a ofna 6 gear spider diff. i have the fuild but I broke the stupied diff seal and I cant seem to find were to order them can some help me in my time of need..
You dont have to be faster than the dog just your friends!
Dont's buy that. It's too expensive. You can buy just the 4 orange o-rings and 6 screws from nitro house. I just bought 5 packs of those for my diffs. Btw, you have 8 spyder gears instead of 6 like you thought. You also count the 2 bigger bevel gears.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
I was going to say the hyper buggies share the same part. I have a set of gaskets like that and they don't quite match up. You may be able to poke holes, but only two screw holes line up on the spiders. I would try to get the orings either way to be safe.
FWIW tho, I've heard those gaskets are good on the other diffs to keep them from leaking as the orings are a bit lame.
Yup, I agre with you Finnster. I have the Ofna mutilaor diffs and those use the paper gasket. I looked at the ring gear and the Hyper series have a little lip built into it for the o-ring to sit in preventing the oil from leaking out. However, if you decide to use grease, you can use those paper gaskets.
Revo with OS .18TZ
