07.09.2008, 08:37 PM
Yup, I agre with you Finnster. I have the Ofna mutilaor diffs and those use the paper gasket. I looked at the ring gear and the Hyper series have a little lip built into it for the o-ring to sit in preventing the oil from leaking out. However, if you decide to use grease, you can use those paper gaskets.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
