07.10.2008, 04:59 PM
Bloody odd if you ask me - 5mm difference - why bother!
Slayer
Length 22.36 Inches (568mm)
Front Track 11.65 Inches (296mm)
Rear Track 11.65 Inches (296mm)
Weight (no fuel) 7.47lbs (3.39kg)
Height (overall) 8.43 Inches (214mm)
Wheelbase 12.7 Inches (323mm)
Front Shock Length GTR™ Aluminum 3.43" (87mm)
Rear Shock Length GTR™ Aluminum 3.43" (87mm)
Front Tires Slash 2.2" (Pre-Glued with Inserts)
Rear Tires Slash 2.2" (Pre-Glued with Inserts)
Wheel Diameter 2.2 Inches (56mm)
Suspension Fully independent Progressive 2 Rockers
Front Wheels 2.2" Satin-Finish
Rear Wheels 2.2" Satin-Finish
Gear Ratio (1st Gear) 15.75:1
Gear Ratio (2nd Gear) 10.05:1
REVO 3.3 REVO 2.5R
Engine TRX® 3.3
Racing Engine TRX® 2.5R
Racing Engine
Starter EZ-Start® EZ-Start®
Chassis Type Extended Chassis
3mm 6061-T6 Aluminum Standard Chassis
3mm 6061-T6
Aluminum
Length 20.650"
525mm 19.469"
495mm
Front Track 16.378"
416mm 16.378"
416mm
Rear Track 16.476"
418.5mm 16.476"
418.5mm
Center Ground Clearance 4"
101mm 4"
101mm
Height (overall) 10.375"
264mm 10.375"
264mm
Wheelbase 13.7"
348mm 12.5"
318mm
3.43" (87mm) GTR™ Aluminum
3.43" (87mm)
Weight (RTR no fuel) 9.8lbs (4.448kg) 9.4lbs (4.26kg)
