TruckBasher
TruckBasher's Avatar
07.11.2008, 05:17 AM
Definitely make sure the motor screws aren't too long. That has been a common problem around here with the Feigaos. If all is well then just face the fact that Feigaos are cheap and if you overload them they will get really hot and fail. Done. The MMM is not at fault here.
Definitely an issue with Feigaos
I havent run my 8XL again but i noticed this when I was mounting it on the E-revo...it damaged 1 wire...I will try to run in soon (E-revo currently out of commission) and see if it will have the same result
E-Slayer direct drive to diff
