What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.11.2008, 03:19 PM
You probably have shortened the life of the cells but I would put in a car and gently run it back down to 3.7v under supervision (in a safe place) and balance charge again properly.
Originally Posted by auto2 View Post
hyperion charger . totally my fault. i was charging one pack and had balance tap hooked up to a different pack that was 1/2 charged. pack never got hot or even warm and i am dishcharging it slowley with a test light inside a lipo sack. doen to 3.8 volts.....
Arkt1k: Whoa whoa whoa- why would you suggest putting an overcharged lipo in a car to discharge it? That is not a good idea. So what if the car is in a safe place...sure noBODY will get hurt but your car could be burned to a crisp!
auto2: So the charger was set for the wrong cell count?? 0o Thank you for using a lipo sack instead of your car!
