Ev1er
07.14.2008, 01:29 PM
with the medusa 2200, MM esc and 2 x TrueRC 15c 2s 8000mah lipos, what speed and runtime will I get ?
azjc
07.14.2008, 01:43 PM
with stock gearing expect speeds 40-45 mph and runtime around 30 mins and as TeaxasSP said it also depends on driving style, you wont go wrong with either of the setups...(2000,2200)
Finnster
KillaHurtz
Finnster's Avatar
07.14.2008, 01:47 PM
If it were me I would go 5s on 5000mah packs with the 60mm 2000kv motor and gear for 40mph. Don't even consider the 50mm, its too small. The 60mm is pushing it as it is.
Don't overgear too much and push the motor too hard, else go for a bigger motor. You should get 45-1hr bashing.
You can try 4S, but don't overgear the motor. Your looking at 35mph gearing perhaps. Long runtimes tho on 8000. I would think an hr.
