Gustav
Gustav's Avatar
10.06.2005, 01:20 PM
A 4s(1p) pack is 14.8 volts,the 2s2p is 2 2s in parallel,only giving 7.4 volts.EDIT; i see you said using 2 of them,sorry.
How many NiMH cells can you charge at once? For example charging 2 10 cell gp2200 packs would take alot less than 2 hours and weigh about the same as 16 sub Cs.Maybe about an hour at 3 or 4 amps?
What setup/truck do you have in mind?
