Well, I just finished making all the parts for my centre differential conversion and am going to post a full step by step guide of the installation. Hopefully it will help anyone wanting to do similar to their Gmaxx's.
Okay, so here i've got a pic of all the parts needed for this install (the diff is an Xray XB808 centre diff with a 42t spur gear on it):
As you might be able to see, i have shaved the top and bottoms of the CD mounts down to lower the diff into the chassis a little more. I have also drilled a hole through one of the diff mounts which bolts to the motor mount too to help reduce flex. I am using two 3mm plates of carbon for the motor mount, again to reduce flex and hopefully prevent the stripping of spur gears.
Now that the motor mount is put together, the diff and top plate go on, nothing too complex here...
