TDC57
TDC57's Avatar
07.15.2008, 06:40 PM
Dammmm Jordan..
This the best GM I have ever had the pleasure of seeing, great update!.. I can’t wait for the video. As always just an absolutely outstanding job Sir..
You just single handed kick my two GM builds rite out of the water..
Great job jordan...
Nothing!.. Hahahahaaa..
jordan...
one.five.two.seven
07.15.2008, 09:32 PM
Thanks alot Shaun
...and i wouldn't say that, your Gmaxx's work
have a good one
jordan
drkros3
07.15.2008, 09:56 PM
what batterys are you going to be using?
jordan...
one.five.two.seven
07.15.2008, 11:16 PM
I'm going to be running 2 3s packs in series for 6s. Definately 5000mah and probably 25c. I'm thinking along the lines of Flightpower or Neuenergy etc. at the moment. I've found a place to get Neu 3s 5000mah 25c packs for $130 each, pretty good deal i think.
drkros3
07.16.2008, 12:55 AM
wow that thing is going to be rip lol. cant wait for a vid.
oh and seeing this thread has got me thinking about maybe getting a neu motor. cause im running a lot less kv then you are on 6 cells and its the limit of the motor. (or i dont really want ot push it any more)
jordan...
one.five.two.seven
07.16.2008, 01:16 AM
i see what you mean, 6s on this motor means roughly 50,000rpm. Which i think is comfortably under the 60,000rpm limit of the Neu motors. Reason i chose this kv is so i could get the max performance out of 6s, because i don't want to be spending big $$ on heaps of lipos and HV ESC's.
drkros3
07.16.2008, 01:21 AM
haha yah thats another reason. i can only go up to 80 amps and 6 cells lol. and i think i might be at the limit of my gearing. cause i know if i gear it for any faster it well go over 80amps. but at least the esc well shut down befor it goes over 80
TDC57
TDC57's Avatar
07.17.2008, 03:08 AM
So when is "D" day Jordan (??)
jayjay283
jayjay283's Avatar
07.17.2008, 04:59 AM
lol Jordan, is that a Neu or a 8 cell maglite strapped on that badboy !! Sweeeet
jordan...
one.five.two.seven
07.17.2008, 05:30 AM
I'm assuming 'D' day stands for 'Drive' day Hopefully soon, i e-mailed Mike about some custom length centre shafts, so hopefully they won't be too far away. Can't wait to see how those v2 MMM's perform as well...
@jayjay: ok you got me... so thats why my torch wouldn't switch on, and my car would only light up
mtbnjim
07.18.2008, 03:32 PM
this deserves a patent... great job!
TDC57
TDC57's Avatar
07.20.2008, 04:10 AM
Jordan,
Just use the 3905 ones until you get your custom ones made..
Yes "D" stand for Drive day.. I know you would know..
Have a great one Sir...
Shaun.
jordan...
one.five.two.seven
07.24.2008, 07:19 AM
I never had a 3905. The only 'stock' emaxx i've owned is the very first version with the narrow suspension
Well, i have talked to Mike and it should be around 2 weeks until i get the custom bones. I also just ordered a DX3R, MMM v2 (backorder) and a couple of pinions.
D-day is approaching...
George16
Supermaxx
George16's Avatar
07.24.2008, 07:42 AM
What's the length of the dogbones you need?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
jordan...
one.five.two.seven
07.24.2008, 08:50 PM
pin to pin, the rear is 168mm and the front is 43mm
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
