George16
Supermaxx
George16's Avatar
07.19.2008, 07:38 AM
How would I know if the fan is not working anymore? Or should I say, what if the fan fails to come on at 140*F and fries or thermals the MMM? Any built-in safety feature?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Jeremy1976
07.19.2008, 09:48 AM
Good question I was wondering that myself.
KINGSKID
KINGSKID's Avatar
07.19.2008, 10:45 AM
most of us won't be able to get the monster max to the point of thermalling. I run a 1.5d on 4s in a buggy and when the original fan failed the esc only got too 175 degrees. That was on a track in race type conditions in low 80's heat and a fifteen minute run. If your running a tamer motor or a slipper in a truck or truggy you may not need a fan at all.
George16
Supermaxx
George16's Avatar
07.19.2008, 08:40 PM
Like you said,
. What about the rest that can thermal the ESC? There is always the possibility and a newbie might take faiulre of the fan as an indication that the ESC is still cool even though it's not.
I don't have any problems (knock on wood) yet on my V1 on 1515 1Y on 6S. However, I will be exchanging it for the V2 once the backlog is over.
Revo with OS .18TZ
KINGSKID
KINGSKID's Avatar
07.19.2008, 09:44 PM
Like you said, . What about the rest that can thermal the ESC? There is always the possibility and a newbie might take faiulre of the fan as an indication that the ESC is still cool even though it's not.
George, Are you infact in that situation? If your running that setup in a truck or truggy and geared to race and not too the moon or in an above average climate, probably not. I've been one of the fortunate ones with a v1 monster. Hooked up my fan to my rx almost from day one. I've run overgeared just to see what could happen. this esc is pretty darn tough IMO
