NEED HELP IN LAYOUT(suggestions pls)
cornolio
cornolio's Avatar
NEED HELP IN LAYOUT(suggestions pls) - 07.18.2008, 03:13 AM
im currently finishing up on my project,and this is the layout im thinking of
most of the xt8 projects here have their weight biased to the rear and have their esc elevated from the chassis.is it big of a difference if i do it this way?
another concern is the clearance of the spur and battery tray,im currently using a pretty small spur(44T).im running a neu 1515 1y so ill probably need to use a bigger spur.this is the only place i can use the tray without seriously hacking it.
any input would be greatlt appreciated.im putting this on hold until i get enough info from you guys.thanks
xray xt8 MMM neu1515 1y
hotbodies ve8 novak HV 6.5
hotbodies cyclone tc
mugen mtx4(nitro)
lst2(conversion ongoing)
  Send a message via Yahoo to cornolio
TDC57
TDC57's Avatar
07.18.2008, 03:37 AM
if you could lift / install your ESC (Nice MMM) over your rear drive lines you could move your tray back a few more mm but other than that, it's sold.. Where is your RX going (??) above your steering servo (?)..
Here are two examples picture of what I’m talking about..
or you can do this (??)
Other than that it looks GREAT!.. keep us updated on your bad boy!..
Nothing!.. Hahahahaaa..
cornolio
cornolio's Avatar
07.18.2008, 03:47 AM
tdc57,
i knew you would come to my rescue:).but...i think im not yet skilled enough to make one of those.but i guess i have to try.i still have time until our next bash session anyway.thanks
anymore inputs would help.fire away
mugen mtx4(nitro)
TDC57
TDC57's Avatar
07.18.2008, 03:50 AM
OOOoooo sorry then..
Just so you know, it great the way it is, that was just a suggestion to better what it almost perfection now..
TDC57
TDC57's Avatar
07.18.2008, 04:00 AM
I can make you like the first picture group, just pay for the parts (??) or do this..
Easy ESC mod..
Get some Lexen (thick not thin) and cut it the size of your ESC, drill (4) holes, one in each corner and then go to lowes or home depot and but some pipe that has the centers threaded out or use hollow pins and run long srews through the centers and attach at the top. Once the plate is secure use doubeled sided tape servo tape and zip teis…
Bammm it done, looking good and now your able to move your battery try back for a better CG..
Just a thought / suggestion..
Best of luck and have fun with it..
tc3_racer_001
tc3_racer_001's Avatar
07.18.2008, 04:02 AM
good idea! i may try that one...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
cornolio
cornolio's Avatar
07.18.2008, 04:03 AM
btw,this is just my first conversion.all my previous ones i got used and just tried to improve on them.that is why i need this to be good one.
mugen mtx4(nitro)
killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
07.18.2008, 10:52 AM
You could just mount the MMM to the center diff plate. Check your local hardware store for a 90 degree countersink bit. (metric uses 90, standard uses 82 degree) That way you can make the screws fit flush and have a nice flat centered esc mount and you'll have more room to shift the weight of the battery. If you're hard on your buggy or like big jumps, you may also want to wrap a zip tie around the MMM. I've had the case pop apart on me a few times.
cornolio
cornolio's Avatar
07.19.2008, 01:25 AM
i tested it at the track today with the first layout and it handled quite well.i have to do more testing coz i stripped the spur.my fault,didnt mesh well and i didnt have a spare.it really handles well,just needs a good driver
tdc,
i think the idea you gave me wont work coz my batts sit very high.id have to set it as high as the center diff,i dont like the way it looks sitting that high.but the current layout gives me a lot of oversteer going right off power
mugen mtx4(nitro)
TDC57
TDC57's Avatar
07.20.2008, 03:54 AM
Great to hear it runs Good... Sorry about the spur gear, you can pick one up from A-main hobbies or stommerhobbies the XB8 will fit also well, your what 46T spur (?)
I cant wait to see out in August at the bash on the 24th..
Have a great one..
