WTB: Neu 1515 Series Motor & Question -
07.21.2008, 05:16 PM
Hello all,
After running a 4S lipo pack through my Feigao 8XL, thats when I realized...man this thing is not going to work out...it is just heating up way too fast and it will never last under race conditions.
So...I need a neu motor. I'm posting it here because there is no way in my wildest dreams I could ever (at my age and occupation) afford to pay the full price of one. So those used Neu motors that you don't want....LMK how much you want for them because i'd like to purchase one!
Possible motors i'd be real interested in:
1515 1Y
1515 2.5d
1515 2d
1515 1.5d
OR any other Neus that will run well on 4S lipos.
Maybe even a Medusa??
I'm not going to run over 4S lipos because otherwise the batteries get way too expensive, so something that runs well on 4S, and something that can work with my MM speedo without burning it up...
The amp draw on these neus are much higher than that of an 8XL I assume correct? The temps of my 5000mah Zippy-H batts were around 120 degrees after running them in my 8XL.
As I said i'm not going for speed more so just going after efficiency and cool running.
If i find a deal and I want to buy it from you...I can't send the payment to you until august 1st because I won't have money until then...
Thanks,
steve
If you're gonna run a 1512 on 4s in a truggy, I'd go with something like a 2d or 1.5y. It'll give you higher rpms and you can just gear down. Should run smoother, especially on startup...
YES, mike has got the 1512 2D in stock! Its 234, i should probably get the endbell cover too.
Brian, the 1512 1.5y is 1900kv.
but do you think the 2d will run hot with 4S? I've never had a neu and I just want to know the temperatures i'd expect.
And do you think this motor will heat up the lipos more or less than a Feigao 8XL would?
I run a 2d on 4s in my buggy and I like it a LOT! It was supposed to be a 2.5d when I ordered it, but some error in marking the box vs the motor got me the 2d. Even geared 46/16 in my Hyper8, temps were good - even at ~55mph. Now that I've geared to a more reasonable 46/14 (IIRC), it's much more controllable. I love being about 1 foot from a jump and still clearing it with ease.
