Duster_360
07.22.2008, 07:18 PM
I measured 3.18V on one pack, and 3.8 on the other.
TC, I saw you post on the adaptor. I'll have to do that. Hyperion taps are the same as Flightpower, right?
No, not quite- Hyperion same as Polyquest, E-Tec, Poly RC, True RC, Maxamps, Xcite and Impulse.
FlightPower same as ThunderPower Apex, MPX and someothers I've not heard of. If you'll ck ALL eRC site for bamance adapter, they list the common ones.
http://www.allerc.com/product_info.p...oducts_id=3160
tino_ale
07.23.2008, 11:17 AM
What is the open-circuit voltage you should not pass with A123?
Typically, when I check the voltage of my packs after running the truck, what's the minimum I should see If I don't want to abuse my A123?
