I think it would be fairly easy to fab your own motor mount for the lst2 with an pieces of angle aluminum. You could then use mikes pinion adapter and the nitro motor mounts for adjusting the mesh. Your other option is a direct to diff outrunner which desmo has done on here.
Just curious what about the revo setup you don't like though? What are you running in it?
