J3110
07.29.2008, 03:46 AM
Recently had this issue with my mashers on stablemaxx titans.
I did the boiling method and found that 20 minutes seemed to give the best results. The glue will turn yellow and brittle.
Only problem is the discoloration of plastic and if you have chrome rims, it ruins the finish.
My rims were white and then yellow after the boiling, so I dyed em black and it worked out fine.
Reason I did this was to kill the baloning of the mashers on the BL-Maxx by running a couple rings of duct tape inside the tires...worked like a charm.
There is also some kind of glue dissolver that you can get at hobby shops that I understand works pretty well. Most likely it has acetone in it if that is what appears to work the best.
