rootar
rootar's Avatar
07.29.2008, 07:29 AM
you could always go oldschool and use fingernail polish remover (free if your married, have a girlfriend, or have a sister or mom in the house), i wipe it on with a cuetip around the bead and pull the bead out each time so that im slowy working it loose deeper and deeper, then i use a new blade on the razor knife and just shave the plastic so not to cut the bead of the tire, then once you get one side loose flip the tire insideout and use a very small tip flathead screw driver and get it inbetween the bead and wheel and thne just run it around it to pop the that side loose.
i was doing this last night lol ill post a picture tonight i got 2 of them off un harmed but i dunno if i wanna mess with the other 2 or maybe try another method listed.
