E-Traxxer
08.02.2008, 10:09 PM
Like the solid center from Ofna that I've been using in my BPP and Ofna buggy .
I'm not sure if we are on the same page. I didn't explain it very well. I'd try to explain it with words, but pictures are even better!
Notice the brakes on the left hand side (rear) connected to the center diff mount like normal.
The brakes on the right hand side (front) connected to a shaft with outdrives on each end.
Between the middle part (where you cant see) would be a driveshaft connecting the center diff to the "faux-center diff" (on the front)
Picture of the brakes on the rear, nothing too special.
Picture of the brakes on the front:
If this makes any sense, it would be using 3 driveshafts total. Is there anything wrong with doing this, as It makes things quite a bit easier for me..
