Trakpower charging and balancing
jnev
jnev's Avatar
Trakpower charging and balancing - 08.03.2008, 03:33 PM
I am looking specifically at this pack:
http://www3.towerhobbies.com/cgi-bin...&I=LXUYY2&P=ML
At the moment, I use a MRC Superbrain 989 for charging with a Hyperion LBA10 for balancing. Can I use this same set up for charing/balancing the Trakpower pack? Because everywhere I look, it says that the V-balancer is required...
I was thinking I could just make an adapter with deans on one end, and 4mm connectors on the other end to put into the pack. Would this work for charging?
As for balancing, I don't even see any balancing taps or a place to input balancing taps... how would I go about using my current balancer (LBA10) with the Trakpower pack?
Any help is appreciated. Thanks!
