rchippie
rchippie's Avatar
08.04.2008, 03:03 PM
Originally Posted by Fast5sRevo88 View Post
Well i didn't keep a check on the temp but i'm geared 16/46 with an RCM heatsink, u could put your hand on it after running an 8000 mah lipo. there was no smoke. The motor has been ran about 8 times i'd say on 4s 6 and 8000mah packs. This is a Nemesis XLT-4 which i was told is roughly a 9XL if that makes a difference. Before i knew better, i ran it twice in an G3r revo on 5s 6000mah pack geared at 22/72.
I dont know anything about the nemesis ratings. All i know is that if a electric motor doesnt turn over . More than likely something is locked up . either a bearing or the rotor . Someone else will have to chime in to try & help you out.
I just re read your thread . If your saying your negitve esc wire de soldered from the ESC. You are diffenitly drawing to many amps for some reason . The esc would have to get pretty hot for that to happen . Is that what happened ?.
REAL MEN RUN BRUSHLESS
