Gee
A Horse's Ass
Gee's Avatar
08.05.2008, 03:20 AM
I have the mm's (not laying around their in other rcs) I could put in it, but then I would need to try and water cool them also. That's one of the reason the model of esc that I linked to above was appealing to me. They had the water cooling already set up. Has the fwd/rvs brakes, and can handle the 2s lipo. The cheapest one, the 25amp is only 32.00. So blowing up two of them wouldn't be that expensive. If it is a sure fire explosion running the 25amps. I wouldn't get them. If the odds are 50/50 or better that a 35amp esc might not blow up. I might gamble the 84.00 dollars for two of them. Once it starts getting into the 120 dollar range. That's a little different for some reason to me.
The sidewinder didn't come to mind for an esc to use. Two of them would be a bit of money plus the water cooling for them. I did notice last night when I was on the cc looking for amp info. They don't recommend the sidewinder with any of their motor above the 5700. I guess that should of have given me a better clue of what I was getting into.
This was just an idea to throw in the villian, make the long trip to the lake and try it. I rarely get a chance to run it now. If I lived on a lake or was at one alot. There wouldn't even be an issue about what to get for it. The best I could afford.
