azjc
08.07.2008, 06:43 PM
Originally Posted by Trick440 View Post
Just Revo 2.5 conversion,
locked into 2nd, Std transmission gears.
Revo center diff.
Motor brake
Single steering servo
Quark 125b
Neu 1512 2.5d
17/54 gearing
Flightpower 4500, 30c
That should be the basics.
I will order a larger 19 tooth pinion. Should I pickup one more? If so what size?
Thanks.
since the biggest spur for a Revo is a 40 tooth ..are you using a different brands spur?...and the 1512 might have more problems gearing up not as much torque as the 1515...and what voltage battery are you running?
