08.09.2008, 08:33 PM
If the magnet is toast, it will be shattered into 2 or more large pieces, and come away from the shaft. The binding you describe sounds more like a dud bearing really- make sure there is no debris inside the motor, and that there windings are crossed as they exit the can (or any loose strands causing a short somewhere).
