MetalMan
MetalMan's Avatar
10.16.2005, 11:39 PM
Originally posted by Gustav
Didn't you run it with a center diff at first?If so can you remember what it did.I'm curious to know as i'm contemplating the same thing as joeling.
I did for a little while, but it wasn't very long. The motor plate I had made was weak, so I made a new motor mount setup that used a solid shaft (but no slipper clutch).
