TO BEc or NOT TO BEc...not just for Patrick
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
TO BEc or NOT TO BEc...not just for Patrick - 08.11.2008, 03:52 AM
I'm sure Patrick could answer this best, but I cant expect the guy to spend all his time tooling around the threads...i'm sure he has enough to do
Anyway...
I have a MMM V2 that should be here soon. I also have a spankin new CCBEC sitting here as well. After hearing hints that some V1 failures came from the MMM internal bec, I thought this would be the safest bet. But now that the MMM has been revamped, is using the BEC warranted/needed/suggested?
Ideally, I would prefer to use the MMM the way it was designed...stand alone
...But I do have the BEC....
what would you do?
and more importantly....why?
thanks in advance,
Jarrad
PS, in case it matters....
this will be run in an e-revo. (12lbs?)
Using a tekno Neu 1515/1Y , with
1)two TRC 15C 8000'mAh 7.4 run in a series
2)two Zippy 4300 3s 20-30C run in a series
