08.11.2008, 04:03 PM
How did you "dial out preload"? Just curious.
I'd start with the middle sized sway bar. You can also play with roll over/balance by changing which hole the uppper hinge pins are in.
I had quite a bit of preload on the front and rear to get the ride height up. When I moved the pushrods to the center hole on the lower a arms it raised the ride height quite a bit. So I moved the preload collars back and the suspension felt better, not as stiff. I need to check the shock oil and see if they are full of oil or not.
What weight oil should I use? I guess that all of the traxxas silicone oil is the same, I have plenty of that...
