blueb8llz
08.11.2008, 06:55 PM
ok this new setup ran like crap! haha. it actually rolls more on turns now even tho it sits waaay lower. i was thinking the softer suspension would just let it squat as i turn but ill just roll. the extra ground clearance is not worth the crappy handling! so back to the option 1 but this time ill put the shock mounting (shock towers) on the outside hole instead of the middle to gain like a few mm's hahah. and ill keep the lower mounting (A arm) on the outside.
this little adjustment wont make my truck run crappy again would it? should i just leave the shock tower in the middle hole? im just trying to gain as much height possible...
