MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.12.2008, 07:53 PM
If you are running on 6s an Feigao 11xl or 12xl is a good cheap motor. An 8xl will run stupidly hot. I have the 11xl but haven't been able to test it fully due to the MMM issue.
The 2 speed is useful though. When I first ran my car it was pulling a huge number of amps but the car was going into second really quickly. I adjusted the shift point screw so second kicked in later and it dropped the amp draw considerably on the second run. Due to the MMM failing though I don't think I was able to actually hit second gear though on the second run due to space limitations. So I don't know if when it hit second it would pull more or less amps then what it was when it was set to change earlier. My guess is it would pull a bit less.
