08.13.2008, 04:03 PM
I believe there is an 'auto lipo' setting that will detect how many cells you are running, but whether this is default or not im not sure. Start your castlelink programme first, then with your castlelink, make sure you plug in the little pcb into the usb lead, then plug that into your PC/laptop. Now connect the pcb castlelink to the rx lead of the MMM, and it should be detected by the PC and programme.
Ever heard of the Unslow harness for running a dual BL setup?..
