ffactory666
08.20.2008, 06:50 AM
Originally Posted by blueb8llz View Post
doing the drememling on the cases should not void the warranty. if it does, i will be pretty upset as i was told by one of the customer service reps from CC that i should dremel the casing when i told him i had a fan failure.
The CC rep told you to dremel the case , why was this not done from the factory then
I did not cancel my back order ( as i was going to ) after seeing the mostly positive results with V2 and it looks like the order is being procesed tomorrow . However i am not impressed that you still have to do the same mods to V2 as you did with V1 and the CC reps are recommending the mods .
Why weren't these issues resolved ?
