It is possible to get it to arm with that radio, but you won't ever get it perfect. That is an airplane ESC, so you'll need a pistix adaptor to translate the radio signal into something the ESC understands. After that, it's easy.
im just getting a red flashing led and the bec isnt sending any power to the servos
am i suposed to have an external bec?
( new update, if i plug in a recever pack it works!.............. so should i have an external bec or is it suposed to have an internal and its just not working?)
That is correct. The HV series do not come with a BEC. You'll need to buy the CCBEC or simular UBEC, or stick with the reciever pack if you're running so much voltage that you need an HV controller.
cool thanks, i have a castle bec but i though that the hv110 had an internal
Nope, the HV is an Opto-ESC. Meaning it requires brains power from an external source. We are just used to ESCs that have their own built-in BEC. Even when we "disable" it by removing the wire, it still is powering the internal circuits. Any HV ESC will be an Opto design unless it happens to have a switching BEC built-in. The losses of a typical linear regulator are too great after just 3s, and who runs 3s on a 10s-12s controller?
Yeah, there are few choices for really HV BECs. DimensionEngineering makes one, and so does Western Robotics. I chose the WR for it's obvious construction beefiness and to try something different. The KoolFlight UBEC is good for up to around 9s (10s is a tad too high at 4.2v/cell).
