bensf
08.27.2008, 05:57 PM
Any of the batteries with enerland cells are good. I have had good luck with TrueRC and Zippy for the cheaper ones.
CRTIM
08.27.2008, 06:15 PM
as far as pinion gears go ...i see a few different types.....with either the stock metal CRT spur or the KYOSHO nylon spur ...which type do i need?....will both spurs use the same pinions ? thanks again guys for the help
