feistyacorn
feistyacorn's Avatar
08.28.2008, 10:08 AM
Originally Posted by SV6000 View Post
I also loosened up the M3x14mm bolt that joins the over diff piece of Cf and the X-brace piece. That reduced the amount of gap between the the bulkhead and shock mount. My only question is how tight does that bolt need to be? working on the pics
Hi SV6000! Are you talking about "G" on the second page of the instructions? http://www.gorillamaxx.com/images/gm...ctions-chr.pdf
I made the bolt tight enough so there was not excessive play. The bolt is ment to hold the rear diff tight. The screw actually pushes the diff down. Once you get the rear assembled, make sure the diff doesn't move up and down.
