Originally Posted by Pdelcast
Hmmmm -- interesting. So it works fine on Auto Lipo, but as soon as you set to a specific cutoff voltage it stops working?
I'll have Richard double check the software on Tuesday -- probably something a little buggy in V1.19
Thanx!
Patrick
Thanks for your help, Patrick.
To clarify, mine didn't work at first with the custom cut-off set at 12.8V. When I checked it again, the cut-off was set to something like 236V. When I tried to change it, the numbers in that box moved around randomly. I clicked on the arrows next to the box and was able to get it back to 12.8V and it then worked properly with the custom setting.
Well, it worked properly until its second run, then it gave up the ghost. I suspect that it's related to the twin-servos in the E-Revo pulling too much from the internal BEC, because my V1 is still working great in a different Revo with a single weaker servo.
That's my suspicion anyway.
Thanks!
Brian
