Desmo
08.31.2008, 01:10 AM
The e-lst conversion is not too bad. I have the forward only tranny with the internal swap for better ratio. I use a "the dude racing" single speed hub with a 59t tin spur and a 24t RCM hardened pinion. Problems are the lack of a prefabbed motor mount (until the dude gets his ready for sale) and a spec battery tray. I intend to use motor brakes, so the brake servo will be gone, and the battery tray will go between the rec box and the tranny. I will mount the esc where the fuel tank sits... Will have to make a battery tray, use some kydex like always.
I didn't go the standard route with my lst. Mostly just time. $ wise the most expensive thing was the esc. Even the LST2 chassis was less than 100.00. It handles so much better than the early emaxx that I want to sell my emaxx but I have to much in it I would go with an e revo if I was starting out right now.
Its changed some more since these where taken.
