tc3_racer_001
tc3_racer_001's Avatar
09.01.2008, 05:11 PM
did you know they are now installing foam under the board... guess they must be listening :)
opened it up and was suprised how small it is, to fit all that stuff in the little board then make a gigantic case for it all. took off the bottom sticker so i can actually stick it to my mount, seems dumb to stick it on the bottom but o well.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
e-mike
e-mike's Avatar
09.01.2008, 05:23 PM
right for the foam..... i remove this foam after my second failure(my esc failed once and restart after power on)my esc failed second time and i open the case....i was tinking that the foam was my problem(maybe causing heat of the bec whatever.....)but...my v2 failed third time after 3 min....nothing to do...simply died
D8t on juice!!
