09.01.2008, 04:27 PM
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 47
Pinion Tooth Count: 14
Total Voltage: 11.1
Motor KV: 3500
Tire Diameter (inches): 3.5
Tire Ballooning (inches): 0.3
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.36 : 1
Total Ratio: 10.91071 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 38850 RPM
Vehicle Speed: 43.43 mph (69.77 km/h)
Estimated Adjusted Speed: 41 mph (66 km/h) - 6% loss
Effective KV Value: 3500
KT constant: 0.39 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
The first couple fields you can use the presets, crt.5 diffs, center diff direct drive for tranny, stock is a 47t spur
14t pinion on stock tires will give you about 40-41MPH depending on ballooning of the tires it may be more
