09.03.2008, 12:52 PM
Shouldnt do.
If you just bump up the voltage from 3s to 5s without changing the gearing, the esc will run hotter like Brian said. If you set the gearing for 5s, then went down to 3s without re-adjusting it, the esc should run cooler due to a much reduced load.
