rchippie
rchippie's Avatar
10.25.2005, 01:14 AM
Daf you said you modified the female slider on a lathe. Do you took the grooves out of the slider then pressed in the bearing ?. Also is that a wheel axle with the threads cut off ?. Thank's
REAL MEN RUN BRUSHLESS
