RacerX Gmaxx Roller for Sale
I will post pics up here this evening once I strip the elctronics off it. But, it has Hybrid bulks, 8 spyder diffs, 6mm cvd's, rear set backs. customized heat sink rear plate for esc (mainly used for the Quark 125b). It also has the V! slipperential from RCM, the first edition. Proline server saver steering and more! Please let me know....
troynelson_672@msn.com. If anyone has seen sjcrss set up, it is much like his except mine has the set back rear arms.
The diffs are in perfect condition as well as the cvd's. The only thing wrong with this truck is that one front lower arm has a bend in it where the shock goes. Does not affect anything however. I will get pics up as soon as I can this evening.
Please keep in mind that this is only the roller. You will need the batts, esc, ubec, servo, rx, and radio.
