jhautz
jhautz's Avatar
09.05.2008, 04:25 PM
I guess that would require me to break that little seal that says "warrante void if broken" so I'll just use it like it is for now.
There are a few ways to do that with normal PC PSU depending on design:
1: Look for a small PCB mounted pot and make small adjustments to see if it tweaks the voltage or something else.
2: Load down another rail. If this is truly a 12v PSU only, that can't be done.
3: Look for a voltage feedback wire and trick the PSU into thinking the voltage is lower than it really is, so it boosts the output.
to make it...
or break it...
Silent...But Deadly
