Go Back   RC-Monster Forums > Support Forums > Novak
09.06.2008, 10:40 AM
Originally Posted by jayjay283 View Post
I have a 15lb Muggy with big Joe tires and I want to run Novak because im loyal, What do you recommend as gearing for a 14lb monster truck with 8" 1lb each wheels ? (x4) its all roar right
Sarcasm???
Seems like it to me. If you are serious, I would go with the 6.5 system on 5s and gear as low as you can. You will need to go up to a 62t spur from the crt, and most likely a 14t pinion. Diff ratios are 11/45 in the muggy, and with 8" tall tires the stock 46t spur will not offer enough reduction, unless you use a 5-6t pinion....
